VSS causing limited on 1st gear shift?
Old Apr 29, 2009 | 09:16 PM
jay_rich's Avatar
I was wondering if my VSS sensor is causing my car to bounce the limiter on my 1-2 shift. My shift point was 6100 and I lowered it and it still bounced off the 7000rpm limiter.
My buddy says it could be a bad VSS.
Or just wear on the trans, Im sure a 4l60e thats somewhat built can only take so much abuse running 11.7s lol
Jay
Old Apr 30, 2009 | 06:19 AM
12SCNDZ's Avatar
Not likely the cause. If it's reading right ion the dash or a scanner, there's probably no problem with it. More likely the 2-4 band not coming on quick enough.
Frank
CPT
Old Apr 30, 2009 | 07:15 AM
AL SS590 M6's Avatar
Moderator
Jay
Ran a stock 4l60e for drag use for 7 years, with the last few in the very low 11s at 120+. A built one should handle 11.7s easily.
Old Apr 30, 2009 | 07:43 AM
camarobird92's Avatar
That's the same problem I am having with mine. Lately it has even been starting to slip out of 4th gear.
Old Apr 30, 2009 | 12:05 PM
12SCNDZ's Avatar
This sounds like the 2-4 band, also.
Frank
CPT
Old Apr 30, 2009 | 01:08 PM
jay_rich's Avatar
Oh well we will see how fast it explodes after the turbo build is finished (which is pretty well there)
Then TH400!!!
Jay
Old May 1, 2009 | 09:11 AM
Performabuilt's Avatar
Supporting Vendor
Jay
I am A little confused you signature says 87 iroc then 4L60E.
Assuming theres been some swap done or we are not taliking about the 87 I see you not setting the RPM but what about the MPH they both must be met,
When the car shifts just off full throttle what does the shift feel like?
What is the fluid condition?
Old May 1, 2009 | 01:31 PM
Jay has an LT1 and 4L60E combo swapped into his IROC.
Old Jun 5, 2009 | 05:54 PM
jay_rich's Avatar
lol posted this just before i got the car running, trans lasted about 30 Km on the with the turbo lol. I have a built TH400 awaiting me to install
Hello manual valve body! And trans brake!
Jay
F'n1996Z28SS
Aug 23, 2023 11:19 PM
blac94Z
Jan 12, 2015 05:44 PM
simple
Aug 2, 2002 03:30 PM
