vig 2800 stall question
Old Nov 3, 2005 | 11:25 PM
nb 96 z's Avatar
Will this be ok to install before putting in a cam? I mean how is the driveability or should i wait to install it after a cam swap?
Old Nov 3, 2005 | 11:49 PM
Bersaglieri's Avatar
Re: vig 2800 stall question
Sure throw it in there. It will be worth alot with some sticky tires in the 1/4.
-Dustin-
Old Nov 4, 2005 | 09:20 AM
Z-RATED94's Avatar
What rear gears are you running? It does make a difference on how the converter feels.
Old Nov 5, 2005 | 11:25 AM
nb 96 z's Avatar
2.73's as of now
Old Nov 5, 2005 | 09:38 PM
Z-RATED94's Avatar
With 2.73's it will feel a little loose, but not bad. I started off with 3.23's and went with 3.73's. It felt like the converter was re-stalled a couple hundred lower after that. With that said, a Vig. 2800 with 3.42 to 3.73's is the way these cars should have come from the factory. It's really not that bad on the highway if you can obey the speed limit.
94redform
Sep 8, 2002 03:27 AM
CARGASM
Sep 4, 2002 11:17 AM
Brad 97z
Aug 10, 2002 09:58 AM
TrouserSnake
Aug 7, 2002 12:43 PM
Bill'sWS6
Jul 19, 2002 11:21 PM
