vibration troubleshooting?
Old Jun 12, 2004 | 10:32 AM
chris59405's Avatar
Question vibration troubleshooting?
I have a 97Z M6 that starts vibrating at 70 mph and gets worse the faster you go. the vibration is also worse with weight in the car(4 people,luggage). i have put on a ls1 ds, new u-joints, tires rotated and balanced multiple times at different shops. i don't know what is next any suggestions appreciated. also it doesn't matter 5th or 6th gear the vibration is the same.
Old Jun 14, 2004 | 01:22 PM
Shred's Avatar
Was it a brand new LS1 driveshaft or a used one? I put a POS used LS1 driveshaft in my car and it still vibrates. I should have spent a little extra money and got a new one.
Old Jun 14, 2004 | 02:16 PM
chris59405's Avatar
it was a used one. it wasn't beat up or anything though. did you replace yours with a new one? is it possible to balance the ls1 shafts?
Old Jun 14, 2004 | 03:33 PM
97FormulaWS-6's Avatar
It can be balanced, it's just finding a shop to do a "high-speed" balance.
The shop I used to use only did 3600rpm balancing, you need to find a place that can take it to at least 6K rpms if not more.
It honestly sounds like a DS issue, and see if you can find a shop to do the HS balance. I know you can send it to Denny's, but he's got a 2 week backup on balancing right now. He can get a LS1 shaft to 6-7K rpms balanced.
There are other things that can cause your issue:
Pinion Angle improperly set
Bad bearings in the Pinion
Bad transmission output bushing
Either of the last 2 can be detected by trying to mode the DS up/down/left/right and seeing if it moves a way it shouldn't.
I've been fighting a problem like this for over 18 months, I finally said F-it and just ordered a new DS from Denny's. I tried a LS1 shaft and it didn't do squat, even after having it balanced, although I believe part of it was the shop that balanced it (I have heard some horror stories lately about them balancing shafts; it wasn't denny's who balanced them, it was another local place)
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
tommalcolm
Sep 11, 2015 03:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
