vibration at higher speeds-please help
Old Mar 10, 2010 | 07:55 PM
Roach02's Avatar
So i've always had this problem as long as i can remember but when i'm at higher speeds like 75-85mph and steadily cruising (not giving it gas just maintaining speed) there is a vibration coming from the rear of the car and i can even feel it in the shifter handle (it's a 6spd car). when i slow down sometimes it continues until it gets slower like 65mph and if i'm feeling the vibration and get back on the gas it goes away. What could this be. I noticed the rear pinion seal is leaking and i'm going to replace it and i got diff. control arms w/reloacation brackets that are going to be installed as well but it did it prior to lowering the car. I feel it could possibly be the drive shaft itself. Does anyone have any similiar problem(s) and/fixes for this!? It's soo annoying! and i just balanced my tires so i crossed that off the list of possible issues.
Old Mar 10, 2010 | 08:26 PM
CreatiVe2's Avatar
http://ws6.com/shaft.htm
most of the time a LS1 ds will fix the issue.
Old Mar 10, 2010 | 11:38 PM
Roach02's Avatar
thanks so much. so after reading that i need to just buy a certain part (the part number listed) or just buy a LS1 drive shaft and it'll bolt right up fixing the problem?
Old Mar 11, 2010 | 07:32 AM
CreatiVe2's Avatar
pretty much, you most likely have the stock steel 2.5" (unbalanced) driveshaft. commonly known as "vibrashaft" a lot of the members here experienced it. Apparently there are no long term affects, besides the annoying vibration. however, when i got my car, its the first thing i noticed, and the first thing i replaced. There will always be some sort of vibration at high speeds, due tot he rear axle configuration in these cars. but your issue can be fixed.
4 nuts at the rear yoke will loosen the ds, you need to push it forward (towards the transmission) and then you can move it around, and pull it out. a very easy 15 min job.
95chwagon
Oct 16, 2015 12:24 PM
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
