vibration above 3500 rpms??
Old Sep 27, 2004 | 12:17 PM
Gary 95 Z28 M6's Avatar
vibration above 3500 rpms after spec clutch install
I recently put in a spec stage 4 clutch and steel flywheel in my car about 500 miles ago. This weekend I decided to get on it a little bit for the first time. Well as soon as the rpms got to 3500 the car started vibrating. It goes away as soon as you push in the clutch. Has anyone had any problems with the stage 4 or flywheel being out of balance? I know it is one of the 2 because it does starts vibrating as soon as it hits 3500 rpms in my driveway. Thanks for any help!!
Last edited by Gary 95 Z28 M6; Sep 29, 2004 at 04:18 PM. Reason: add more to title
Old Sep 29, 2004 | 04:17 PM
Re: vibration above 3500 rpms after spec clutch install
any ideas???
Old Nov 20, 2004 | 07:52 PM
Re: vibration above 3500 rpms??
just to give a final update, the car is finally fixed. i ended up sending back the stock flywheel and the new spec flywheel back to spec. they matched the balance on the new flywheel to the old one. its finally good to go now!
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
