transmission problem?
Old Nov 11, 2009 | 11:07 PM
smooth operator's Avatar
I have a 1994 Z28 with the a4 transmission and 144,000 miles. A few weeks ago I noticed that when driving at highway speeds if I push on the accelerator to speed up a little I can feel a slipping/jerking in the drivetrain. At first I thought it was the engine missing under load but as the problem is getting a little worse I have begun to realize that I believe it is the transmission causing this feeling. This problem doesn't seem to occur when taking off and it seems to upshift ok even if you step into it. I thought that it might be the transmission slipping in and out of overdrive but I still have this problem even if I put it in 3rd and keep it from shifting into overdrive. Has anyone else had a similar problem? Is this the start of the transmission going out or some other problem? Any suggestions on what direction to go with this problem would be appreciated.
Old Nov 12, 2009 | 02:20 PM
n2ceptor's Avatar
3rd/4th clutch packs are notorious for going out.... Might be time for a rebuild...
warmeck
Mar 16, 2015 07:02 AM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
edxiel
Jan 24, 2015 07:40 PM
Cam's maro
Dec 28, 2014 09:30 AM
