transmission lines
Old Mar 17, 2013 | 03:44 PM
Chet1185's Avatar
transmission lines
My transmission lines are leaking at the transmission. Just installed new Trans and I cannot get them to stop leaking.
Where can I get new cooler lines?
Posted from Camaroz28.com App for Android
Old Mar 17, 2013 | 04:03 PM
Chet1185's Avatar
Can you buy fittings and use rubber hose?
Old Mar 17, 2013 | 06:20 PM
12SCNDZ's Avatar
Re: transmission lines
Transmission fluid will break down the material that most rubber hoses are made from.
Frank
Old Mar 17, 2013 | 06:23 PM
12SCNDZ's Avatar
Are they leaking between the case and brass fittings or fittings to lines?
Frank
Old Mar 18, 2013 | 12:39 AM
Chet1185's Avatar
Between the line where it comes through the bolt to tighten the flare in
Old Mar 18, 2013 | 09:53 AM
12SCNDZ's Avatar
You can go to your parts store and buy 2 2' sections of line that already have the correct fittings to screw into the trans and 2 compression fittings. Cut the ends off your originals, and bend the new ones to match. Then, just use the compression fittings to mate the repair ends on the original lines.
Frank
Old Mar 18, 2013 | 10:04 AM
Chet1185's Avatar
Ok thanks,I will try it out. Are they just a universal line or vehicle specific?
Old Mar 20, 2013 | 01:12 PM
Chet1185's Avatar
Took the fitting off the shell of the Trans that came out of the car and installed it in this one, leaking is done!
Old Apr 10, 2013 | 07:13 AM
Chet1185's Avatar
Had the lines not leaking but now I notice they are leaking again. Who knows how long.....I haven't noticed fluid on the ground until now.
Also now I see fluid slowly running down the converter. Any idea what would cause this?
This transmission was just rebuilt and a new converter,.I will be a little upset if I have to drop it again because of a seal.
Old Apr 15, 2013 | 08:30 PM
Chet1185's Avatar
Spliced a new piece on and put new fitting in the shell, doesn't seem to be leaking now.
Old May 23, 2013 | 08:47 AM
*Emilia*'s Avatar
Rock auto sells the lines pre-bent for oem fit. We bought 2000ish (I think) lines and changed the connectors to the snap fit ones, makes putting in and taking out a hell of a lot easier.
Have a 94z28.
Apr 16, 2015 09:57 AM
jackpawt883
Feb 26, 2015 09:04 PM
Jazsun
Dec 29, 2014 12:14 PM
