a transmission headache
Old Jul 7, 2009 | 10:08 AM
slammer's Avatar
Angry a transmission headache
i have a 96 1500 pick-up with a LT1 out of a 95 Z28 bolted up to a 3 speed turbo 350 with shift kit. the converter dissengages from the transmission. this is the 3 time it has happened. the first time i took it apart and i just put it back togater and it ran fine for three months or so. it happened again i did the same thing but i spaced the converter closer to the transmission. and two months later it happened again. has anybody succesfully bolted a turbo 350 to an LT1?
Old Jul 7, 2009 | 12:54 PM
Performabuilt's Avatar
Supporting Vendor
The LT-1 style engine has have many 350s bolted to it for many years.
However sounds like a converter spacing issue indeed.
When you reinstall this time measure with the converter pushed all the way back into the trans you want APROX 1/8 to the flex plate if you have more the shim to get as close as possible.
Sep 27, 2015 01:55 PM
Sep 18, 2015 03:46 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
