transco shift kit
Old Jun 10, 2004 | 04:19 PM
crystal01z28's Avatar
transco shift kit
anyone with any info. on this problem would be awesome, here is what's going on....... I have a '01 z28 Camaro, i had a transco shift kit put into it; what's happening to the car is when i take off, between 1st and 2nd gear the car bogs down, if i take my foot off of the gas pedal and then return it to the pedal the car is fine. I was told that i have a torque management system on my car, i was also told that it can be removed or gotten around so that the car does not do this anymore, does anyone know how to get around this torque management system??
Old Jun 10, 2004 | 06:56 PM
Andrew04ME's Avatar
Not to be rude, but it's a Transgo shift kit...
Torque Management system huh? It's possible someone is feeding you some BS. Maybe traction control (ASR) is a torque management system? Start doing some reading in the various forums on this website. Learn as much as you can, educate yourself. As for your problem, i couldnt tell you.
Old Jun 10, 2004 | 07:13 PM
Capn Pete's Avatar
Not to be rude, but maybe you should "start doing some reading in the various forums on this site...learn as much as you can, educate yourself" as well .
Torque Management is a legitimate issue/feature. It's programmed into the computer from the factory so that the engine's power is reduced just before the transmission shifts so that the tranny isn't subjected to the full ~300 HP/TQ during the shift. I believe the computer simply retards the timing momentarily, and you do feel the sensation that the car stops accelerating for a moment. Not all programmers can remove the torque management, but I believe that LT1/LS1 Edit can do it, as well as maybe the Predator programmer?
That is likely the symptom you're experiencing.
Old Jun 10, 2004 | 09:18 PM
AmericanPsycho's Avatar
You are correct, the computer pulls the timing on the shifts. The Predator does delete TQ management automatically when you load the basic program without modifying anything else. I saw a huge increase in power when I dropped the Hypertech and bought the Predator. Best thing I ever did. I also have a transgo shift kit.
Old Jun 11, 2004 | 11:47 AM
2001NBMZ28's Avatar
Here's a quick TM explanation from the '02 manual:
http://www.ls1camaro.net/article.php...thread&order=0
The Predator base tune "revises" TM settings, I had mine completely removed when I got my custom tune.
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
RedLineRev
Jan 23, 2003 03:51 PM
TrouserSnake
Aug 7, 2002 12:43 PM
