Trans removal help
Re: Trans removal help
As for the flex plate I always use at least a mild (blue) lock tight and even on the torque converter bolts. As far as the bell housing bolts a good you know its tight will do ad long as all bolts are present.
94 Z28 LT1 4L60E- Mostly Stock 3" Cat back Blowmasters. Chrome rims
+5 HP
+5 HP
Thanks for all the help. As of now, one of the heads of my flex plate to crankshaft bolts is rounded off. Trying to think of the easiest way to get it off, then in goes the transmission. Any suggestions to get it off quickly and easily?
http://m.sears.com/index-g.html#/pro...r=00952166000P
Why are you removing the flexplate anyway?
Sent from my LG-LS860 using Tapatalk
you can also undo... not all the way the two rear cradle bolts. I think when we first did it... that bolt was a bitch... lots of extentions and a swivle was even invovled when we lowered the cradle. Now when doing the trans we get it with a wrench with out lowering the cradle.
GA93FORMULA
Jul 24, 2002 11:38 PM
