Is the Trans Cooler..OK to use? Need help from the pro's
I need a new cooler cause the one I have is to freakin small and with my new 3400 stall Im getting extreme heat build up in my fluid acccording to my Trans temp gauge...has no problem getting to 250+F*
So im in the market for a new one....The one I have now is s POS Hayden tube/fin design that the GVW is well below 20000...
Ive looked around at many and have done searches all over this site and other sites. I know the B&M is the cooler of choice but I was wondering what you guys think of FLUIDYNE coolers? ..I found this one at a good price and its rated at 25000 GVW..I need to know ASAP..I want to order it tomorrow and have it by this weekend...thanks!
Heres the Picture and write-up for it...it should do, correct?
Fluidyne Extra Heavy Duty, Multi-flow, Low Pressure Drop, High Flow 18,000 BTU (17,000 BTU to 25,000 BTU depending on air velocity. 25,000 lbs GVW Rating Automatic Transmission Cooler: Super Performance Part #10029. Thin; only 1" thick. Oil Cooler Measures 18" X 8 3/4" Overall. Hi-Tech Patented 9-Pass Design Provides Maximum Cooling Efficiency: up to 50% more cooling over traditional tube & fin coolers of the same size
THanks Frank!...I was hopeing you would respond cause of your expertise with trans and coolers. I just placed my order for the cooler and will recieve it Friday. Now, lets hope that the temp comes down with the new cooler.
