trans
Old Nov 23, 2009 | 05:02 PM
z28camaro1090's Avatar
trans
what trans came in the 1993 camaro z28? 700r4 ?
Old Nov 23, 2009 | 05:47 PM
bw_hunter's Avatar
4L60
Later cars came with the 4L60E
Old Nov 23, 2009 | 06:22 PM
crash4cyl's Avatar
Originally Posted by bw_hunter
4L60
Otherwise known as the 700R4.....Trans is identical internally no matter the designation. The "E" is electronically controlled rather than line pressure increased by a TV valve. The 93 is technically called the 4L60.....but it is still controlled by the TV attached to the throttle body via cable.....so it is still a 700R4, GM just changed the name from 93 and on. As for hard parts they are identical.....only difference is in the valve body of the trans..
Old Dec 20, 2009 | 01:18 AM
RACEON's Avatar
The 93 is a one year only 4L60, and 92 and older were titled as 700R4. The 93 has different valve body and a 5 pin plug on the drivers side vice a 4 pin plug, for the lock up circuitry.
force10
Aug 10, 2015 08:30 AM
ricks95TA
Jul 23, 2015 12:59 AM
jackpawt883
Jul 20, 2015 06:32 PM
dolfan324
Jul 17, 2015 10:34 PM
Fastbird93
Jul 11, 2015 04:37 PM
