TRANNYSTUCK In 2nd
Old Nov 7, 2004 | 05:29 PM
BoobSter-lt1-z's Avatar
TRANNYSTUCK In 2nd
I had my tranny rebuilt about 1.5yrs ago and I had them install a B&M Shift Kit with the Street/Drag set up. About 2 months ago i replaced the fluid with royal purple but i only dropped the pan and changed that fluid out. All the other fluid in the torque converter and lines was not drained out.
Problem :
Sometimes (once a week maybe) the tranny will not shift from 2nd to 3rd and the rpms will go as high as I allow them to. I throw the car into neutral and pop it back into Drive and it shifts normal again
This only happens when I go about 1/2 way on the throttle. It will happen when the car is cold or warm.
I dont know if maybe the old tranny fluid was not synthetic and this royal purple is and it is causing a chemical reaction or if my tranny is starting to tell me that its going out again
At the time of the fluid change I also changed the filter and there was shavings in the pan but i figured that was somewhat normal right?
Your responses are greatly appreciated
Old Nov 7, 2004 | 06:28 PM
Re: TRANNYSTUCK In 2nd
Correction
- I Meant To Write That The Current Tranny Oil Is Royal Purple
Synthetic
Old Nov 7, 2004 | 06:40 PM
NOMAD's Avatar
The B&M shift kits will usually burn up a trans. Sounds like your due for a rebuild now.
-Shannon
Old Nov 7, 2004 | 06:53 PM
again?????
any reccomendations as far as changing the tranny oil again???
This happened as soon as i put the royal purple synthetic oil and took it out for a test drive...that is why i am questioning this because it seems weird
Old Nov 7, 2004 | 11:49 PM
GreenDemon's Avatar
Might as well save up now, different fluid will only buy you time, at best.
Rebuilt autos almost never last as long as the originals.
Old Nov 8, 2004 | 10:06 AM
I Guess my question is if different type of tranny fluids mixed together can cause your transmission to shift improperly. For example, non-synthetic mixed with synthetic. The reason I ask is because as soon as I changed the tranny oil and pulled out the driveway, the car did this but then it went away...
Old Nov 8, 2004 | 11:03 AM
Capn Pete's Avatar
-Shannon
Is this actually a common problem, or did you hear of 1 case of this happening, so you're assuming that all B&M kits burn up trannies? I put a B&M kit into my car a couple months ago and it seems to shift fine?
Old Nov 8, 2004 | 01:57 PM
Same Here...i Put In A B&m Shift Kit About 1 1/2 Years Ago And It Was Shifting Perfectly Fine...nice Firm Shift From 1-3rd And Then Overdrive Was A Lot Smoother.....
I Dont Want To Blame The Shift Kit Because It Happened As Soon As The Tranny Fluid Was Replaced
I Was Thinking Maybe Since I Used Synthetic And It Has Detergents To Clean Up The Tranny I Figured It Did Its Job And The Filter Might Be Plugged...can This Be A Possibility?
Old Nov 8, 2004 | 09:15 PM
GreenDemon's Avatar
Almost none of the 4L60Es seem to last more than 100k miles or so...
And my tranny took a crap a few months after I changed the fluid & filter. Oh well, if I get another one I guess I'll just leave it alone. Kind of wierd having something that could fail if you do maintenance on it.
Old Nov 9, 2004 | 11:04 AM
WELL BEFORE I REBUILT MY TRANNY, I TOOK IT TO JIFFY LUBE TO HAVE IT
FLUSHED AND THEY WOULDNT REPLACE THE FILTER BECAUSE THEY SAID
THE FLUSH WOULD CLEAR OUT THE FILTER LIKE NEW...SO I FELL FOR IT. I LEFT JIFFY LUBE AND DROVE OFF AND IT WAS SHIFTING FIRMLY AND WAS
CHIRPING GOING INTO 2ND AND I WAS LIKE ...SHOULD HAVE KNOWN
THAT THOSE WERE JUST SIGNS THAT MY TRANNY WAS GOING OUT. 3 DAYS LATER MY CAR NEVER SHIFTED INTO OVERDRIVE AND ABOUT 1 MONTH LATER
GOING TO MY HOUSE I WAS SLOWING DOWN AND FELT THE CAR SHIFTING INTO 2ND AND WHEN I GAVE IT GAS AT THE SAME TIME ALL I HEARD WAS
LOUD GRINDING AND FROM THERE MY CAR WAS RUNNING AT 3500RPMS GOING ABOUT 10MPH UNTIL I GOT HOME AND HAD IT TOWED THE NEXT DAY AND HAD THE TRANNY REBUILT AND THE B&m SHIFT KIT THROWN IN.
Old Nov 10, 2004 | 12:56 PM
Any Suggestions?
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 10:09 AM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
