tranny temp gauge and sender
Old Mar 17, 2004 | 01:17 PM
94zLT1's Avatar
wanna get this..a bit expensive 69.99 + the sender 15.99
is this a easy installation (just inscrew the sender in the tranny and put in the new one..is it that easy?) how accurate are these?
http://www.nordskogperformance.net/streetdig2.html (M9007)
http://www.nordskogperformance.net/sending.html (S8013)
Old Mar 17, 2004 | 02:52 PM
94zLT1's Avatar
anybody?????
Old Mar 17, 2004 | 03:53 PM
I don't think there is a temp sensor in the stock 4L60E. But there is a plugged port on the passenger side that you can use for a temp sensor.
Old Mar 18, 2004 | 12:54 PM
The more I thought about it, the more I realized there is a stock trans temp sensor on the 4L60E. It is "internal" to the tranny, and feeds the PCM, so you don't want to just "unscrew" it.... you will get trouble codes. The rest of the info is OK... You need to add another sensor, and there is a port on the passenger side of the tranny.
Old Mar 18, 2004 | 01:36 PM
Russ95Z28's Avatar
Yes there is one built into the trans. Its does feed the PCM and it will show up if you scan or log your car. Your PCM will adjust the shift/line pressure based on this temp reading.
Old Mar 19, 2004 | 12:36 AM
triumph's Avatar
Thats a bit much for the gauge. I think i paid $40 trans temp and $15 for sender . There is a guy on ebay that sells cyberdyne gauges for alot less. I got my FP gauge with sender for less than that price of the trans temp gauge. Email me for the guys addy. and use the port in the side of the trans. Steven
Magenta_Hearts
Mar 29, 2017 08:54 PM
dylan1303
May 22, 2015 12:24 PM
Biggiebound
Apr 21, 2015 11:28 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
