Tranny swapped but slight issue
Old Aug 28, 2008 | 07:41 PM
stvski80085's Avatar
Hey guys. I just dropped my performabuilt tranny in today. I tinkmy pinion angle is off because i get a lot of vibration especially on the highway. I put a new Tranny mount in that seemed a littletaller than the pervious. Could that be why the angle is off? I didn't do the installbut I did watch the guy that did it. I know the drive shaft is fine because it wasn't doing this on the way to get this done. The mount is the olny thing I can think of that may be a problem. i got it from summit and they say it is the correct one but the one we took out was a little more flattened. Just wanting to know if could be something else.
Old Aug 28, 2008 | 07:42 PM
Sorry for the bad spelling
It's been a long day. Thanks for any advice.
Old Aug 28, 2008 | 09:22 PM
Green96Z's Avatar
What kind of mount was it? An OEM replacement or aftermarket polyurethane?
Old Aug 28, 2008 | 09:49 PM
Performabuilt's Avatar
Supporting Vendor
If its was and after market poly mount that may very well be the source of your vibration the stock mount is soft and mush for a reason to absorb drive train vibration and keep you from feeling it .
I hear , read and get calls from guys having this issue after installing these mounts with no other changes made all the time
Old Aug 29, 2008 | 10:58 AM
Yes it is a poly mount
I am planning on switching back to a stock one. I figured that was the culprit. I should have known better. I thought it being taller was the problem but it just may be how stiff it is. Now if I can get it to go into park I should be good to go. It does shift great now compared to what it was doing. It was wierd though because whn we were done th motor started missing a bit. I don't think it has anything to do with the tranny so I have someone checking it out. I made sure everything was put back and tight. I took the day off work to watch them do it because I just dn't trust some people enough and I like to learn this stuff. i am pretty good on most of this but know expert. I was surprised that with the right tools it really isn't that hard of a swap. Thanks for the help guy's.
Old Aug 29, 2008 | 11:35 PM
Supporting Vendor
Did we figure out park ?
Old Aug 30, 2008 | 01:23 PM
Re
Frank I think it is working now. I just picked it up from having the water pump and opti replaced. Not cheap. I have only drove it home so far but it does seem like it is in park now. I am going to make sure a lttle later. I still need to change my wires out and it should be running good. I am going to take it for a better test once the wires are replaced. I should get those done tom. Had to get everything fixed so it hasn't been drove much.
Old Aug 30, 2008 | 04:00 PM
Supporting Vendor
Cool good to hear let me know how things go
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
cmdeshon
Jan 4, 2015 11:15 AM
nballisru
Dec 14, 2014 05:01 PM
Snoman73
Nov 17, 2014 07:22 PM
DJCobol
Sep 3, 2002 05:36 AM
