Which tranny should I got with
Old Feb 27, 2009 | 04:20 PM
bkpliskin's Avatar
hey guys, guess what
when we were installing all the engine part in my sig, we found out I had apparentely destroyed my flywheel and completely ripped my tranny to shreads, cracked and everything
well, I'm about out of money with this current setup, like straight broke.. so
what's my best option for a tranny
should I go with a TH350 or a 700R4, or should I find a used T56 to swap in while I'm there?
what kind of prices should I expect and which ones will bolt right up, any input would be greatly appreaciated... I'm in quite a pickle
Old Mar 2, 2009 | 08:47 PM
doc221978's Avatar
The best choices would be a 700R4 or a TKO 600. The TH350 has no overdrive, and the T56 has such an extreme 6th gear it won't be of much use under around 80 mph.
The 700r4 sounds best for you. Maybe $150 for the tranny at the most, and about the same for a rebuild kit with good steels and clutches through summit. Just remember to get a lock-up controller if it has a lock-up convertor.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
