Tranny replacement options (currently T56)
Old Sep 2, 2003 | 04:30 PM
Lions3's Avatar
The T56 is pretty much done for.
I have about a 1000$ budget to work with.
What are my options?
Remember I'm from Canada, where 4L60E's cost 1500$ stock.
I could get a well built TH350 with a high stall for about 750$.
How much work is involved in moving to a TH series tranny?
Old Sep 2, 2003 | 11:17 PM
kgkern01's Avatar
If you can remove the tranny yourself and save some $, just get it rebuilt. Some people are going with stronger parts, such as Viper T56 parts, also when they rebuild. You should be able to get it rebuilt for about $1000. I had mine done for $900, but just replaced the bearings and the synchros that were worn/gone, and they also charged me the labor to pull the tranny (about $250-$300).
Old Sep 3, 2003 | 01:49 AM
rskrause's Avatar
Moderator
If your car sees much street time, you will not be happy with a TH350 and it's 1:1 top gear. This year, I am using a TH400. Even with 3.42's, it needs another gear for enjoyable highway driving. Once I decide for sure that I am going to keep the TH400 (still an open question) I will get the Gear Vendors OD unit. Nice, but heavy and expensive. In any case, there are costs associated with the TH350 beyond the tranny. You will need a cross member, tranny cooler, and shifter. And to get your speedo to work, you will need the right reluctor for the TH350 and PCM reprogramming.
If you can't DIY, I think your best option is to remove the tranny and find someone local who can take it apart and replace what is worn/broken. You aren't going to get a complete "rebuild" for $1K Canadian. But you might be able to do what I describe within budget. Another option: T56 from a wrecked car.
Rich Krause
Old Sep 3, 2003 | 07:35 AM
RamAir95TA's Avatar
I don't know about you but....
Old Sep 3, 2003 | 11:31 AM
Lions3's Avatar
Maybe a 700R4 would be a safer bet?
It's not easy to find wrecked Fbodies around here. We don't get all hopped up on moonshine and go for a rip in the backwoods like you folks might
How easy is a 4L60E swap? All I'd need would be a PCM and some small accessories right?
importkiller94
Jan 17, 2015 09:03 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
