Tranny...
Old Dec 16, 2008 | 12:57 PM
Camaro Kid94's Avatar
Tranny...
Ok guys, found myself a 98 Camaro, it's a auto, V6 car, but the motor is bad. Otherwise the car looks like new. I am thinking if I decided to buy it, I'll pull the V6, find a LS1 and make a swap. My question though is, Tranny wise, Would a 4L60E from a Lt1 work? Or is there something computer/bolt up wise that won't work? What about a t56 from a Lt1 car? I have access to both. But I am not sure which will work. Or if either will work at all.
Old Dec 16, 2008 | 01:15 PM
Green96Z's Avatar
LT1 transmissions are not interchangeable with the LS1. Different bellhousing bolt pattern, not to mention the longer input shaft of the LS1 tranny.
Old Dec 16, 2008 | 03:19 PM
blue 79 Z/28's Avatar
yea it wont work, you will need a transmission from an LS1 v8 car either auto or manual. the t56 cant be swapped over even to the different bellhousing because the case has a different bolt pattern.
Old Dec 16, 2008 | 04:18 PM
Ok I didn't think so..... Dang. Oh well. Thanks!
eanhl2004
Nov 18, 2013 11:05 AM
jimbob65
May 16, 2010 09:08 PM
1994TransAm
Oct 2, 2004 12:26 PM
darkoverlift
Aug 2, 2003 01:53 AM
