tranny
Old May 5, 2005 | 07:36 PM
Everett's Avatar
tranny
i have a 97 camaro with the a4 tranny i keep tearing them out i was woundering the price and where is the best place to find a t56 conversion for my car i want everthing to look and preform something the factory would have done i cant decide what i want to do buy a new auto or make my car a 6 speed all opions considered
Thanks for the help
Shane
Old May 5, 2005 | 08:43 PM
12SCNDZ's Avatar
Re: tranny
Your 4L60E can be built to handle a large amount of HP. We've got them running 11.0's @ 124 MPH. Launching on a 175 shot...Pulling the front wheels 8" off the ground on a 1.51 60 ft. time.
Frank
Old May 5, 2005 | 08:53 PM
Everett's Avatar
Re: tranny
ok another question if i was to get a tranny from you what would it coust for me to get a complet tranny? also can i run the race rebuild on the street all the time i dont take my car to the track i just dont want to have to do this again. whant i mean by a complet tranny is all i have to do is drop mine out take the tourque off put on new tranny and reinstall quick simple and min downtime
thanks for ancering all my dum questions
Shane
Old May 5, 2005 | 09:43 PM
12SCNDZ's Avatar
Re: tranny
Shane,
If you don't race the car, you might get away with a "performance rebuild".
We'd need your transmission to build...We don't have any '97 cores at this time.
You should NEVER reuse a torque converter in a new transmission...Without atleast having it sent back to the manufacturer and having it checked and cleaned out. As a side note, TCI isn't the most reputable 4L60E converter manufacturer, either. I've seen too many TCI converters come apart.
Frank
Old May 7, 2005 | 01:33 PM
Everett's Avatar
Re: tranny
the tci converter that i have only has about 3 or 4 thousand miles on it do you think it would be ok to use i realy cant aforde to replace both tranny and converter at this time
Old May 8, 2005 | 09:58 AM
12SCNDZ's Avatar
Re: tranny
If the transmission is wasted, you should NEVER reuse a converter. I, personally, won't even give a warranty on a transmission if a converter is reused.
The trans. and converter share "common fluid". This means all the nasty crap from the transmission is now inside the torque converter. When you try putting a used converter in front of a new transmission, you immediately fill the new transmission with all the garbage out of the converter.
No, there's no way to "flush" a torque converter without cutting it apart. I can have your cut and cleaned for around $100...Providing it's not damaged inside.
Frank
Old May 8, 2005 | 05:03 PM
Everett's Avatar
Re: tranny
ok i see what you are saying. just as a side not the tranny is dot completly junk the car still will run and drive just that drive and overdrive are starting to slip under a hard load but thanks for the help
shane
Old May 9, 2005 | 10:38 AM
1SlowFormula's Avatar
Re: tranny
Just a little FYI - if it is slipping, it is putting junk (clutch material, and metal) into the fluid and that junk will still be there after the new tranny goes in unless the converter is replaced or sent out to be redone.
Old May 9, 2005 | 01:59 PM
94Zpower's Avatar
Re: tranny
Shane
the full Race trans is fine for the street I cant possibly be happier with mine and it is mostly street driven .
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
