Torque Converters, etc. . .
Old Oct 29, 2004 | 08:43 PM
hitdr9's Avatar
Question Torque Converters, etc. . .
I'm looking to quicken my '02 Z Vert Auto off the line. Other than changing the gear ratio, is a TC the next best option? I'm not looking for a HP boost; I just want to use what I have under the hood earlier, as in 0-60, etc.
How much is involved in getting a TC installed, and is it worth what I want to achieve?
Any and all advice is welcomed. Thanks!
Old Oct 29, 2004 | 11:35 PM
hitdr9's Avatar
Re: Torque Converters, etc. . .
Thanks! How is the 3500 stall for a daily driver. Too loose? The Z is not my DD, but I'm not looking for drag applications either. I want it to move on the road immediately, so will this eat my tires if it's just a weekend car? The 2.73 feels slow, so that's why I'm asking about the stall. Thanks again!~
Old Oct 29, 2004 | 11:45 PM
Knowklew's Avatar
how are torque converters in the winter/snow?
Old Oct 31, 2004 | 08:51 PM
MISOMWS6's Avatar
Not bad at all, heck some say it's eaiser because you have more throttle controll/play when taking off from a stop. Just don't go WOT
Old Oct 31, 2004 | 08:59 PM
MISOMWS6's Avatar
The TCI3500, Yank SS3600 or vig 3200 are all good verters for a daily driver. They will take a little gas to get moving...but not much at all, nothing to worry about. It will not "eat your tires" if you drive it normal. Yes, they will spin eaiser when you stomp on it but like I said if you drive it like normal you will hardly notice the stall is even in the car.
Old Nov 2, 2004 | 01:03 PM
Pro Built Automatics's Avatar
Make sure when you change the torque converter, you remove the checkball capsule from the end of the input shaft & replace the "O" ring. Your TC installation instructions should tell you this.
Old Nov 3, 2004 | 12:41 AM
AL SS590 M6's Avatar
Moderator
Originally Posted by robvas
TCI 3500 Stall
It's worth every penny. You can do it yourself, or any tranny shop will do it for a reasonable fee. It's basically removing and re-installing the transmission.
Jack the car up, put it on stands, remove your driveshaft, unbolt the bellhousing of the transmission from the engine, put some blocks under your oil pan so the engine doesn't tip back and smash stuff on the firewall, remove the dipstick, remove the shifter cable, remove the tranmission fluid lines that go to the radiator, remove the dust cover from the trans, unbolt the stock converter, remove the crossmember, slide the transmission out, remove the stock converter, pour a quart of fluid into the new converter, stick it back in the trans (make sure you get it in ALL the way), and reverse what you've done so far. Installing a tranny cooler is cheap and recommended when you do this.
Pretty close Rob.
Ammendments for LS1 cars:
no dust cover you need to pull the starter to access converter bolts.
Dip stick is bolted to the back of the head not the bell housing.
Got to pull the torque arm mount. Some pull the TA but it's not necessary.
Rear O2 wire clips are bolted to the trans
There's a vent hose on top of the trans
There's a big wiring harness that needs to be unhooked also
Old Nov 3, 2004 | 12:42 AM
Moderator
On an LS1 car ?
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
