Torque Converter, will it only help on the launch?
Old Sep 30, 2003 | 01:08 AM
My Mighty White 95 Z28's Avatar
I am planning to purchase a Midwest torque converter. I was wondering will it only help on the launch? Or will it also help on a roll or when you are at 70 and punch it? Any help and information would be greatly apprecaited. Thanks.
Old Sep 30, 2003 | 03:16 AM
AL SS590 M6's Avatar
Moderator
It helps everywhere that you want to accelerate hard. Especially where you have dead spots with a stock converter. You know, when you floor it and it won't down shift because you're going to fast for a downshift. With a converter the absolute lowest rpm after flooring it will be the flash stall of the converter. Which will be way higher than with stock.
Old Sep 30, 2003 | 05:16 AM
rskrause's Avatar
Moderator
Not exactly the same topic, but you may find http://web.camaross.com/forums/showt...hreadid=174531 interesting.
Rich Krause
Old Sep 30, 2003 | 03:04 PM
JEDCamino's Avatar
While I don't know exactly how it works, I do know that when I went from a stock converter to a 3500 rpm stall, I could easily feel the difference at any speed. What kind of stall speed are talking here?
Old Sep 30, 2003 | 06:39 PM
I am planning to purchase a 2800 stall
Eric
Old Sep 30, 2003 | 07:00 PM
JEDCamino's Avatar
Hmm...I went from a stock converter to a 3500, and felt a noticeable difference. Then I went to a 2500 because the 3500 was beginning to have problems and I was having overheating problems at the time. Now I want to go back to a 3500 since I have since figured out the overheating problem, and I originally chose my cam for that stall speed. I need to just stick with one or the other. Lol
Old Oct 1, 2003 | 08:52 AM
2001SilverZ28's Avatar
The converter helps mostly off the line, but it will also improve acceleration a little when you punch it when coasting.
Old Oct 2, 2003 | 07:52 AM
FastZinTennessee's Avatar
I wouldn't expect much from a roll, but at least it won't hurt you over your stock stall IMO.
Old Oct 3, 2003 | 03:59 AM
Moderator
Well then you could be easily caught way off guard. I run the converter in my sig. and it's a total beast from any roll.
Old Oct 3, 2003 | 08:09 AM
Ok, then why is it that when people install a torque converter they generally don't gain much if any MPH?? I will stand by what I said, an aftermarket torque converter will not help much from a roll, but it won't hurt you.
Old Oct 6, 2003 | 12:19 AM
Moderator
Before the TC 108mph best. After converter 110.
then added OR y-pipe, SSRA, and skinnies now 111.80
Yank converters are very efficient.
Old Oct 6, 2003 | 12:15 PM
m0nk's Avatar
The reason that a converter doesnt really help with the MPH is because you are flooring it the whole time. While from a roll, or 70 mph, no matter what you hit higher rpms, either your trans shifts, or if the trans dosnt shift then the converter makes up for the trans not shifting to get you into higher rpms.
dboone2172
May 16, 2015 07:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
StansZ28
Feb 19, 2015 07:39 AM
veryslowfbody
Aug 22, 2002 04:31 PM
