Torque converter and rear end help
Ok i Have a 94 z28 camaro with a stock rear end. I dont know for sure what the gear ratio is but i believe its a 3.23 because i read on here somewhere that if your rpo code is GU5 thats what it should be. I have bought a non-lockup converter with 2800-3000 stall. I have a 4l60e with shift kit. I havent put in the converter yet because im not sure if this would be a good setup. The trans shop i got the converter from gave me a valve to put in the pump to help change it to a non- lock up. I also have the LT4 hotcam upgrade if that helps.
Any comments would be appreciated
I really didnt want to but thats the only torque conv they had in stock with that stall speed. They other torque converter was a lock up but the stall speed was 2300- 2500. Would that be ok for my setup. I was hoping to go with a higher stall but I was really hoping to put it in this weekend, so I dont really want to order one.
Don't use a non lockup converter. Non lockup converters are designed for race only applications, so if you drive the car on the street get a lockup converter. Also, from what I've heard, 4l60e's don't like non lockups. It can heat them up more and take out clutchs easier.
