Torque converter and dyno #'s
Old Sep 28, 2003 | 02:25 PM
Teal96TA's Avatar
did a search to no avail
In what way do torque converters affect dyno numbers? I hear that they can "kill" these cars on the dyno and wondered if there's a calculation or SOMEthing to correct for it. I lost 6 rwhp and 21 rwtq with a better flowing exhaust, FC-1000 ignition, a shift kit/tranny rebuild, and 2800 stall.....and probably 30k more miles. Talking to the dyno guy he said: Did you put a stall in it? They'll kill the numbers on these cars.
Old Sep 28, 2003 | 02:33 PM
rskrause's Avatar
Moderator
Re: Torque converter and dyno #'s
There is no standard conversion. The amount of rwhp loss will vary with the converter. In general, the higher the stall, the more loss you will see, but details of the converter design make this just a generalization anyway.
Fred (Injuneer) has some before and after chassis and engine dyno numbers going from a T56 to a TH400 with a high stall. You must have seen these if you did a search. I think he saw ~12% loss with the M6 and ~20% with the TH400. I don't have as direct a comparison, but think I lost even more with going from a T56 to a TH400 with 4,200rpm stall. I doubt you are losing anywhere near 8-10% with a 2,800 though.
Rich Krause
Old Sep 28, 2003 | 05:46 PM
Teal96TA's Avatar
I can't find his post on it, but it just gets me that because I have a stall I can't see what the minor mods I've done since the last time did for me. Seems wierd that a part that helps makes your numbers drop!
Old Sep 28, 2003 | 07:44 PM
rskrause's Avatar
Moderator
Well, the explanation is not that esoteric. What you see with a converter is (typically) a quicker ET but a bit slower through the traps. Better loss, but less hp at the big end to keep accelerating.
Rich Krause
Old Sep 28, 2003 | 09:12 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Re: Re: Torque converter and dyno #'s
Rich Krause
Just out of curiosity even with the higher parasitic power loss are you seeing faster 1/4 times with the high stall TH-400 than the T-56?
Old Sep 29, 2003 | 01:00 AM
rskrause's Avatar
Moderator
Re: Re: Re: Torque converter and dyno #'s
The motor and blower are different too. It's not completely sorted yet, but it's been somewhat disappointing that my 60' aren't any quicker (to date) than with the T56.
Rich Krause
Old Sep 29, 2003 | 04:28 PM
DarthIROC's Avatar
Re: Re: Re: Re: Torque converter and dyno #'s
Rich Krause
If its on a different set-up are you just have more traction problems than you were when you were on the manual?
How much more powerful is the new set-up
Old Sep 29, 2003 | 05:39 PM
rskrause's Avatar
Moderator
Re: Re: Re: Re: Re: Torque converter and dyno #'s
Not sure whay the 60' aren't better. I need more track time to determine that (with videos, data recording, etc.). I don't know how much more hp the new setup makes, I do know the rear wheel numbers are disappointing. Normalizing for conditions, it only shows an additionl 20-30rwhp in spite of 3-4psi more boost, a better cam and a bit of head work.
Rich Krause
dboone2172
May 16, 2015 07:45 PM
QuickSilver02
Apr 7, 2015 11:12 AM
F550maranello2
Apr 1, 2015 11:10 AM
armedtrigger
Feb 24, 2015 08:30 PM
veryslowfbody
Aug 22, 2002 04:31 PM
