tork master 2400
Old May 1, 2008 | 12:18 PM
1993zlt1's Avatar
tork master 2400
Buddy of mine got this TC he wants some feeback on it He has the lt4 hotcam kit and gets some cam surge at times for some reason would this be an ok conveter for him he picked it up for 150 bucks. Was it worth it. I trust u guys and rather have people who have had it. Then calling up summit.
Old May 3, 2008 | 04:59 PM
1993zlt1's Avatar
anyone BUMP to the top
Old May 4, 2008 | 07:00 AM
Z-RATED94's Avatar
I'd leave a stock converter in before chancing one of those. Tell him to buy a real converter, Yank, Vig, etc. The surge might be his tune is off. That cam really shouldn't have any surge if tuned correctly.
Old May 4, 2008 | 11:39 PM
1993zlt1's Avatar
really?
I have the holeshot i like it.
Old May 5, 2008 | 08:42 AM
Z-RATED94's Avatar
Originally Posted by 1993zlt1
really?
I hope it lasts for you. Any 60ft. times with it?
Old May 5, 2008 | 11:35 AM
1993zlt1's Avatar
Before my cam swap with BFG DR i pulled a 1.9 with it It stall alittle higher then my stock, my stock tc 60ft times were around 2.1 on street tires. But the 1.9 was only 1 of the 2 passes i made on this TC cause I put it in late last year.
Last edited by 1993zlt1; May 5, 2008 at 11:37 AM. Reason: was looking for my old time slips
Old May 5, 2008 | 09:43 PM
Z-RATED94's Avatar
I cut low 1.6x's with mine, big difference. A quality converter will usually drop your et between .4 to .6 tenths. You need a converter change. 1.70 60ft times or better are the norm with your set-up. I'm not knocking your set-up, just trying to help.
Old May 5, 2008 | 11:06 PM
1993zlt1's Avatar
I havent run this steup yet I put it in this winter, I ran those back stock the holeshoot with catback drs and msd6a and jet chips. I pulled a 13.9 at 98. Full weight with a subbox in the rear. I should be pulling that when i run it this year. I ran 14.x without the conveter and without the msd. way i see it i dropped proably .3 tenths with the conveter. witch is not bad for a 2400 stall. This year i will be in 11s on a 75 shot. My buddy ran the same setup i am running a 12.5 with a th350 with a 3000 stall and a 11.78 with a 100 shoot. I wanna be close to 12 flat on a 75 shot maybe break 11s.
Old May 7, 2008 | 01:42 PM
SNOTGREEN's Avatar
You and I have similar plans, just trying to dial the car down to 12-anything w/bolt-ons, then spray it into the 11's. I haven't done converter or gears yet, or driveshaft though, but it's coming. I was looking into a vig 3000-ish lockup and 3.73's. Right now my best on the stock stuff is 1.9's. on BFG Drags.
Old May 7, 2008 | 05:09 PM
1993zlt1's Avatar
Well My buddy just sold me a set of used 4.10s for 50 bucks that he ran a year. There richmonds and i can get them installed for 230 bucks. but broke for the moment but i couldnt pass up his deal. So maybe late this year they will be in cause i dont wanna blow my 10 bolt this early and not have the money to fix it or put a 12 bolt in. So proably by fall or winter there going in .
Old May 8, 2008 | 09:34 AM
Z-RATED94's Avatar
I had Richmond 4.10's and they made a good amount of noise. I have heard of a few cases where they didn't, but that is pretty rare. I went back to the stock 3.23s for a while and then had some Motive 3.73s put in. Very little noise now.
Old May 8, 2008 | 09:50 PM
1993zlt1's Avatar
really made noise, theres sothimg they can do to them or special ones that get some kinda treatment thats suspose to reduce the noise but idk what its called o well. Quick question was it the noise louder then the eninges grumble cause if it is might not be worth it but stuff like noise doesnt really bother me.
Old May 9, 2008 | 09:12 AM
Z-RATED94's Avatar
The noise was annoying, and I have a high tolerance for such. Your call.
Old May 9, 2008 | 12:12 PM
1993zlt1's Avatar
oooOOo i might just save those for a future project then haha.Possibly a drag car.
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
