tire wear
Old Dec 28, 2003 | 07:39 PM
Tofus 93Z28's Avatar
tire wear
im having tire wear issues....
here is the pertinent information
stock rear suspension, no front sway bar, 3.23 gears, 3000 yank converter, et streets 26-11.5-15 tires,telstar wheels, ls1 driveshaft,15# nitrous bottle with accessories and brackets mounter over right rear tire...i usually run tire pressure around 12-15 psi...
seems the inner portion of the passenger rear tire is wearing prematurely...
i have been told the promblem could be tire pressure, tires,wheels,alignment,bent axle, or bent axle housing...( excess negative camber on the suspect wheel/tire combo)
i know i need an alignment verification and i have had it aligned, with stock wheels(16s) with street tires...and nothing in the rear was excessively out...
any input or similar problems/fixes would be greatly appreciated...
thanks in advance
Old Dec 29, 2003 | 12:37 AM
Bad AZz Z28's Avatar
wait, are you saying the ET streets are wearing out?
Old Jan 1, 2004 | 04:20 AM
clarification
my mistake... in my previous post.. it seems i did not specify...
the passenger rear tire is wearing on the inside.....
i dont know what else it could be..outside of a bent axle housing... the axle tube on the right(passenger) side...
any ideas..or am i on the money....with the information i have received from several alignment technicians, and automotive technicians...
what do you guys think?
Boss002
Jul 24, 2015 10:47 AM
Latronaxe
Jul 20, 2015 12:00 PM
Jul 17, 2015 02:47 PM
Boss002
Jul 9, 2015 03:33 PM
Slayer
Jul 4, 2015 03:06 PM
