Tips on removing plastic clip to be able to lock down shifter into 1st
Old Mar 18, 2009 | 07:43 PM
RCREEACH88's Avatar
Heres the deal i have a 95z only has od, d , 2 on shifter but i heard that there is a plastic clip i can remove to be able to lock down into 1st, i pulled the face off and seen the clip i need to remove, i also have a buddy with a 93z that has 1 on the shifter and when i looked at his he has a clip to but its also 2/3 the size smaller, what im wonderin is if i completely remove the clip will i screw anything up i go to ratchet it down into first and i goes too far. has anyone removed the clip and how did it work out??????
Old Mar 18, 2009 | 09:35 PM
'94 Bad A Z28's Avatar
Almost everyone with a 2.73 geared car has removed this clip. If your car came from the factory with 2.73 gears it only had access to 2nd gear on the shifter from the factory. A car with 3.23's from the factory has access to 1st gear from the factory.
Just break that tab off with a flat head screw driver or something, and then you can select 1st gear.
Old Mar 19, 2009 | 09:00 AM
RCREEACH88's Avatar
Yeah mine came with a 2.73, a buddy of mines came with a 323 and he can select 1st but he still has a small clip, what im worried about is it going back to far when i remove the clip.
Old Mar 20, 2009 | 11:03 PM
SpeedZ28's Avatar
I dont know about a clip??? maybe your year is different but my 97 had a plastic stop, I just cut it completely off with a box cutter....heres a link to the thread I started asking the same question, the second or third post has a link with a photo. easy mod.
https://www.camaroz28.com/forums/sho...d.php?t=644364
Old Apr 7, 2009 | 06:13 PM
it's allgood's Avatar
I used a hacksaw on my plastic tab and it took 30 seconds once i had the shift cover removed. the shifter goes down farther and does not hurt anything. have fun burning thru 1st without it shifting into second. lol
Victor Lamb
Aug 26, 2017 02:52 PM
mattstrike
Mar 11, 2015 07:33 PM
rjc1629
Jan 27, 2015 10:46 AM
Lions3
Aug 30, 2002 01:03 PM
