Ticking Noise comming from Rear End!!
Old May 30, 2004 | 02:03 PM
crAzy95z28's Avatar
ok well a few months ago, i side swiped my car, it bent the axel, and messed the rim and brake pads and rotor up..replaced rim, replaced axel and brake and rotor...now i replaced the axel on the passenger side about 1-2 weeks ago and now since yesterday it started to make a CLICK or TICK noise comming from the rear end diff....what could be the problem?
any clues please help FAST as my car is being worked on NOW!!!
thanks
randy
Old May 30, 2004 | 02:22 PM
crAzy95z28's Avatar
ok well put my hand on the rear diff, and i can feel a tick through it, like its hitting inside there or something?
you think the bolt that you undo to take out the long PIN to realease the axel came loose and is tapping agaisnt the rear end? or do you think i need to add some additive in the car? cause i put castrol rear end fluid in it!!
Old May 30, 2004 | 03:13 PM
crAzy95z28's Avatar
ttt
Old May 30, 2004 | 03:50 PM
dnz28's Avatar
hmmmmm. well that ticking noise is most likey your posi chattering and yes additive would help. always add additive when servicing your rear, also read the bottles cause some are not to be used with a posi.
Old May 30, 2004 | 03:54 PM
crAzy95z28's Avatar
you think it could be the BOLT that holds in teh PIN? maybe it came loose? well i bought some kind of castrol and put it in, but i never put in additive...so im guessing add addivtive and see if that works? if not then it could be the bolt huh?
Old May 30, 2004 | 04:16 PM
dnz28's Avatar
It possible, i hate that bolt, im always affraid of breaking it so i never tighten it that hard, i just use lots of locktight.
Old May 30, 2004 | 04:23 PM
dnz28's Avatar
my bad, i read your secound post, if you can actually feel the ticking and its in a consitstant spot when you rotate its possible that the screw came out and the pin that holds the axles in is on its way, I would pull that cover off and check immedatily, last thing you want is to see isyour axle/ tire beating you around the corner.
Old May 30, 2004 | 05:17 PM
crAzy95z28's Avatar
yea i know...well i went to go get royal purple and another gasket for the rear diff....and some additive, hopefully the screw cam loose if it did im going to locktite it this time..shoulda done it the 1st time....
randy
oldschool
Feb 9, 2016 09:21 PM
ModdedNerd
Dec 25, 2014 05:51 PM
FredM
Dec 18, 2014 01:40 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
