Three Series Gears on Two Series Carrier
Old May 23, 2005 | 12:13 PM
Janny's Avatar
OK I just finished up changing my 3.23 to 3.73. I had no trouble at all. I made carefull note of where all the shims came from and put them all back in the same place. I had a professional install the pinion for me. I have very little little gear whine. It sounds and works great.
But, a friend wants me to tackle his rear gears now. He wants to go from 2.73 to 3.73. I see that Strange has a set of gears made for this purpose, so I'm wondering have many of you done this? Does this work out OK re-using shims etc? What are your experiences? I'm a bit leary of doing this. Afraind of the unknowns I guess.
Old May 24, 2005 | 08:00 AM
DB75's Avatar
Re: Three Series Gears on Two Series Carrier
I've had Strange 3.73's for the 2 series carrier for two years now with no problems. I believe Richmond makes 3 series gears for the 2 series carrier also. Good Luck.
Old May 24, 2005 | 12:02 PM
Janny's Avatar
Thanks for the info.
blac94Z
May 4, 2015 12:11 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
cmyname1
Feb 19, 2015 08:38 PM
Elcojoe
Nov 17, 2014 10:27 PM
