Is there anything I can do to stop the tranny from rattling in neutral?
My transmission rattles in neutral when I don't have the clutch pushed in. I tried replacing the TOB when I replaced the clutch disk, but that didn't do anything. As soon as the clutch is completly disengaged in neutral the noise goes away. Is there anything I can do to stop the rattling besides having the clutch in all the time? Its kind of annoying
Re: Is there anything I can do to stop the tranny from rattling in neutral?
Stock mine made noise to. I got a streettwin setup that came with a new TOB and it still made noise. I've learned to live with it, I think it's fairly common/normal for a M6 car unless your talking REAL loud.
Brian
It's pretty damn loud. I can it outside the car with no problem... Non of my friends cars do it either. The tranny shifts fine, but the rattling in neutral is annoying as hell and embarassing.
Originally Posted by 93redBirdMan
its probably a bad motor mount or tranny mount... go under there and take a peek
Mine does same thing, and its loud as hell I can hear it ouside the car and it does it in low rpms. No clue. Read my thread in the drivetrain forum.
I heard once that if there's a rattle with the clutch pedal in, it's the TOB. If it rattles with the clutch pedal out and in neutral, it's the input shaft bearing.
Never had the problem, so I don't know if true or not.
I have poly motor and tranny mounts in, and they are fine, and I don't see how they would make the transmission rattle.
I put a brand new round bearing in once, it was ver loud.
I then put in the square Corvette TOB and its dead silent. It must be better quality.
You are probably hearing the throw-out bearing rattle against the fork due to no pressure being on the fork.
Mine has always done this. I've had a stock pressure plate and bearing, a SLP LT4 setup, and now a SPEC, and they've all done this; most likely because most PPs are Valeo units.
Maybe the square corvette bearing is narrower in the fork channel, and this is why it's quieter? Sure would be nice if an aftermarket company came out with a TOB which would eliminate this noise.
Thomas.
Thomas.
Thomas.
Thomas.
I thought it was this too so I tried pushing the clutch pedal in a little but, and it doesn't do anythink, it stops when the clutch is completly disengaged.
squarehead
Nov 21, 2014 08:02 PM
