th400 swap issues (flexplate)
Old Jun 10, 2009 | 05:23 PM
jay_rich's Avatar
Okay so I got my convertor today that a local store ordered for me. I asked him if it would work with a 153 tooth flexplate. he said it should.
Get the convertor and it says only fits 168 tooth.
What the hell do i do! Ill have to call tomorrow and see what he says
The convertor has dual patterns on it as well.
Its a TCI 241002
So no my only options are order a tci 242101 (fits 153 i guess) but the stall is smaller
OR order a 168 tooth and a new starter? Which flexplate would I need, summit doesn list for lt1 but im sure any 1piece main sbc should work?
My motor is a built 383 so id assume its internally ballenced.
Jay
Old Jun 10, 2009 | 05:25 PM
jay_rich's Avatar
OKay i measured the bolt circle and it measures 10.75 and 11.5 so it should bolt up to the flexplate BUT maybe the reason that it says 168 tooth is because the mounting ears on the convertor stick out? maybe the wont clear?
Jay
Old Jun 10, 2009 | 05:46 PM
mdacton's Avatar
if it has dual patterns it should bolt up no problem
Old Jun 10, 2009 | 05:49 PM
jay_rich's Avatar
Okay sweet yea i measured them and got 10.75 and 11.5
Thanks I just always worry was to much when i get something then come to work and sit on the computer and program for cnc's lol
Jay
Old Jun 11, 2009 | 01:48 PM
jay_rich's Avatar
Okay I went under the car today and tested the convertor out. It bolts on fine, but the 3 tabs on the convertor hang over the starter ring by maybe .100 (from the bottom of the teeth (so no over the entire flexplate)
Should I just grind about .150 of each tab?
Jay
Old Jun 11, 2009 | 03:59 PM
Kevin Blown 95 TA's Avatar
How much metal do you have there outside of the mounting holes? And if you grind away at them, you better do it very evenly (which you probably already know).
Maybe post a pic of this assembled.
Old Jun 11, 2009 | 04:10 PM
jay_rich's Avatar
Here is a pic it isnt mine but looks the exact same.
I think i may set it up on CNC tonight and pickup the center and cut evenly all the way around.
Old Jun 11, 2009 | 04:11 PM
mdacton's Avatar
mine hangs over too...it should be fine.
Old Jun 11, 2009 | 04:18 PM
jay_rich's Avatar
really? the starter doesnt come out that far?
I guess there is always the option of doing it and checking to see if the starter kits and if it does just pull the starter and modify it....or slot the starer so i can pull it more towards the front of the car.
Jay
Old Jun 11, 2009 | 10:32 PM
jay_rich's Avatar
Fixed my issue on our new lathe at work....that was a hard 5 minutes....im like damn this is 700 bucks please dont fly off hahah At least this way i know its even.
Jay
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Nostang 96z
Sep 15, 2002 10:15 PM
Nostang 96z
Sep 14, 2002 08:22 PM
