Th400 running a NON lock-up 2800 vigilante, is this "too much"?
Old Dec 1, 2003 | 06:26 PM
StudyTime's Avatar
Anyone here running a non lock-up high quality converter that doesn't have OD? I cruise at around 2400 rpm (60) and I was wondering how a vigilante with a 2800 stall would act on the street.
I do not want to swap my ring and pinion so my cruise RPM is fixed. I would like to get better acceleration though! Wouldn't everyone? I currently have a B&M 2400 TorkMaster converter. It'll brakestall to 2000 rpm. I want to leave the line with it stalled closer to 3K though. I'd also like to take advantage of a higher STR, but not if it's going to kill my milage because of increased converter slippage.
Yeah... Yeah... this isn't a camaro, it's a truck. No where else on the net seems to be so authoritative on as many topics though. Thanks forum users.
GM claims on an engine dyno, torqe peaks 380 ft/lbs @ 3800.
Ben T.
Old Dec 2, 2003 | 07:02 AM
Smoke T/A's Avatar
I'm really not sure what you are asking about. I have a TH350 with a PT 4200 yank non lock up stall. It is perfectly drivable on the street. Aty least for me it is. At 60mph I crusie at a tad over 3k with 4.10's in the back. I'm sure you will pick up some stall speed going to the 2800. If you want to brake stall at 3k I would call the manufactures and tell them what your set up is. My 4200 will only brake stall to 2700 before it roasts the tires. Good luck.
Joe
Old Dec 2, 2003 | 08:44 AM
StudyTime's Avatar
In a nutshell, what I'm asking is,
If I go with a high quality converter, somethign like Vigilante or Yank, will my current ~13 mpg plunge?
I cruise (my 2200-2400 El Cheapo B&M converter) at 2400 RPM (60mph) and I get minimal slippage and make somewhere around 13 miles to the gallon.
Will going with a 2800 or 3000 stall converter necessarily kill my milage because I don't cruise at such a high rpm being I don't have a TCC to lock i up?
That's the question. I mean, yeah... If I could do a 3200 Vigilante I'd be all over that but not if my milage dropped from 11/13 to say... 8/10. Any personal experiences? BTW, I do very little "in town" driving.
Perhaps this could better be put as; how close does cruise RPM need to be to stall speed to still make decent milage on a mild small block?
Ben T.
Old Dec 2, 2003 | 11:33 AM
Smoke T/A's Avatar
Ahha! I would go with a 2800 lock up stall if you want the best gas mileage (over a Non lock up verter) and a little more umph off the line. It's hard to say what mileage you will get after switching from your B&M to a yank or vigi. I don't know what kind of efficiency B&M has but I know the yank and vigi's have about a 97-99%. SO you might get better mileage from a Vigilante 2800 than from your B&M 2400 because it is much more efficient. HTH
Joe
Old Dec 2, 2003 | 12:08 PM
StudyTime's Avatar
Smoke,
Your comment of efficiency was the sort of thing I was looking for. I'll try and get somewhere on that one. Now some searching is in order!
You mentioned lock-up? It's a Th400, and it has no lock-up feature. If that was the case, I'd do the seven-pump 3200 stall converter.
Thanks for the help!
Ben T.
Red_94Formula
Jan 22, 2015 12:17 AM
twistedwedge
Jul 27, 2002 01:54 PM
Javier97Z28
Jul 24, 2002 08:13 AM
Camaro90RS
Jul 23, 2002 07:57 AM
smackkk
Jul 22, 2002 05:17 PM
