Th350 Swap, Trans cross member mount ??
I'm doing a Th350 swap and just want to use my stock cross member with the little "plate" mod. Meaning I just want to cut a plate of steal to bolt on there and move the mount location till I can afford a nice new one designed for this swap. I'm wondering if anyone has any dimensions they could give to know how big, and how far apart the holes should be drilled so that when i get the trans back from the shop I can bolt it right up in. Thanks for any help.
Sorry Move to drive train section if need be.
if "the shop" knows what they're doing, you won't need that "little plate". Fitz-All makes a kit that allows you to use the correct mounting location, because it supplies an aluminum adapter that goes between the case and your stock 4L60E extension housing. This also allows use of your stock speedo, torque arm, and driveshaft.
Frank
CPT
Frank
CPT
Frank
CPT
Frank
CPT
I think i saw months ago somewhere that might have sold the plates but I do not remember where, that why i was asking the dimensions so I could just get a plate and drill my own whole.
