TCC lock and unlock mph settings 4L60
Old Jun 26, 2015 | 06:48 AM
Steve40th396's Avatar
What mph should I set in TUNERCAT for converter to lock and unlock at?. 396LT1 2800Rpm Vigilante and 3.73 gears in Corvette. 4L60/700R4.
Right now its set at lock at 52 and unlock at 42. Not sure if those speeds are right. I do have abit of sbudder in the 45 mph area at cruise. Tune is good.
Old Jun 26, 2015 | 05:09 PM
FirstYrLS1Z's Avatar
Re: TCC lock and unlock mph settings 4L60
for reference,my 98Z locks at 40mph and unlocks at 35mph.
Old Jun 26, 2015 | 07:42 PM
Thanks. I went out and datalogged. I realize when I am at low cruising speeds with torque converter locked, it surges. I need to keep the converter unlocked till I get above 50 mph. Is that safe? I have 2800 rpm vigilante, 3.75 gears and two coolers for transmission...
Old Jun 27, 2015 | 06:32 PM
in your 1st post you said 'shudder',your next post 'surges'.
when I'm in 4th(overdrive) gear and convertor locked at low speed(37-39mph),the 'surging' I get is engine surging because rpm(1100-1200) is too low. just like driving a manual 6 speed in 6th at low mph.
shudder would be convertor,surging would be engine. rpm too low in the powerband to be efficient.
Old Jun 27, 2015 | 07:49 PM
Well, the fsm calls it chuggle.. Regardless, it is during converter lock up and the car surges/shudders in gear. Its annoying when at speeds its locked.
I am going to raise the mph for the converter to lock. sound good? Will it hurt going to 55mph vice 45mph?
Old Jun 27, 2015 | 08:11 PM
no reason it should hurt. would be a good question to ask vigilante.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
