T-56 transmission Horse power Question Please help??
Ok motor heads I need some advice here please .
Im getting ready to get a T-56 for my transmission & Im going to be putting it in my 67 camaro , I already have all the mounting hardware I need I bought a kit to mount this in my car .
What I want to know is I have a 427 with around 800 horse will this T-56 hold up , now I dont drag race im more of a Show & go but I do not baby my cars what do you guys recomend here any helpful hints , Somebody told me to have a Viper main shaft installed is this nessary just let me know what you think please I have all winter to get the drive line done .
I live in Toledo Ohio so if anyone knows anyone to see here in Toledo let me know .
THank you in advance for the info I really appreciate it guys!!
JOSH (419)466-9830 is my cell if you would like to call me .
Re: T-56 transmission Horse power Question Please help??
It's fine until you hook up.
On the motor with over 400 at the wheels I snapped my output shaft on a 4k clutch drop. Hooking up breaks parts really fast.
If you just plan on driving it a mild upgrade like syncros and shift forks should suffice. There have been quite a few people in the 700rw range that survive "reasonable" driving.
If your going to run a crazy clutch (street twin or Spec 4+) don't be suprised if you break something. As long as the tires spin you'll be fine.
A couple of people locally have gone 10s at near 130 with stock T56s. They are a hearty transmission, but like anything can be broken under the right circumstances.
I would suggest getting the extreme duty T-56 from FLP. www.flp2win.com. That's what I have.
Extreme Duty T-56
New synchro assemblies
Carbon fiber blocker rings
Steel 3/4 shift fork
Solid keys for 1-2 syncros
Solid keys for 3-4 syncros
Viper cryrogenically treated 30-spline main shaft
Machined tail shaft housing
30-spline 1350 yoke
Extreme Duty T-56
30-spline 1350 yoke
Yes Im going to be just pretty much regular driving , I want to do the hot Rod Power tour stuff like that I go to car shows & what not but If I want to run somebody on the street I want it to hold up sounds good guys Thanks for the info!!
JOSH
JOSH
F'n1996Z28SS
Aug 23, 2023 11:19 PM
