Is the T-56 in the LT1 and LS1 cars the same?
Old May 3, 2007 | 01:14 PM
joey93turbo's Avatar
Is the T-56 in the LT1/LS1/LS2/LS6 cars the same? Will one from an LT1 car bolt up to an LS1, etc.? If not, which is better and why?
Old May 3, 2007 | 01:20 PM
danhr's Avatar
throwout bearing/input shaft are different
bell housing different I believe
can't interchange them
Old May 3, 2007 | 01:39 PM
Old May 3, 2007 | 01:57 PM
ulakovic22's Avatar
Yep, you can't interchange them. Everything he said is true plus the clutch hydraulics are different since the LT1 is a pull clutch and LSx is a push clutch. Also the front adapter plates are different.
Old May 4, 2007 | 08:35 AM
Capn Pete's Avatar
Actually, you CAN interchange them, but you have to change everything from the front adapter plate forward, including the input shaft (different length) .
BUT, everything BEHIND that is identical!!
onefastgta
Mar 19, 2015 10:10 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
USAirman93
Nov 24, 2014 03:37 PM
ChrisFrez
Nov 23, 2014 10:33 AM
