switching from 26 to 28 axles
Old Apr 8, 2004 | 09:03 PM
Ryanrabbie's Avatar
With my stock 26 splines in my 88 IROC, I want to change to moser 28 spline. What else do I need to change to accept these, do I need to change the carrier, diff anything to accept the 28s???
I also will install a stud girdle to the 10 bolt. to do as best as I can till I can afford a 9inch or 12 bolt.
The only changes made to my drum rear end is a set of Richmond 3:73's
Old Apr 9, 2004 | 06:01 PM
Ryanrabbie's Avatar
bump
Old Apr 18, 2004 | 07:11 PM
Ryanrabbie's Avatar
ttt
Old Apr 19, 2004 | 12:32 AM
AL SS590 M6's Avatar
Moderator
You'll have to change the posi. The axles fit into the side gears of the posi and a 28 spline axle isn't going to fit into a 26 spline hole.
Old Apr 20, 2004 | 12:03 AM
onefastgta's Avatar
See if you can get your hands on the slp take-off zexel torson posi's on ebay or the classifieds, all other stuff will bolt up as long as you have a 3 series ring gear.
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
