Swapping Rear End Question
Old May 6, 2007 | 12:31 PM
turnin20s's Avatar
I bought a used low mile rear axle with a bad pinion bearing from a friend of mine for $25 and I set that rear up with new bearings and gears, but my car had traction control and ABS so it has the sensors on the axles and the rear that I got from my buddy has the reluctor ring and the sensor on the housing.
My car doesn't have traction control or ABS anymore so will it matter at all? I just plugged the hole on the rear I bought and unhooked the wheel sensors on the body but will there be any other problems besides my ASR light being on and my ABS light always being on?
Thansk in advance
Old May 7, 2007 | 04:40 PM
turnin20s's Avatar
Anyone?
Old May 7, 2007 | 07:56 PM
ablackcamaro's Avatar
Should not cause any problems if you already have the tc and abs systems turned off. Just as long as there's no open holes in the rear where the sensors went .. but you mentioned you plugged them, you should be fine.
Old May 8, 2007 | 10:14 AM
turnin20s's Avatar
Thanks, thats what I wanted to hear
oldschool
Feb 9, 2016 09:21 PM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
FredM
Dec 18, 2014 01:40 PM
