swaping from a t56 to a th350
Want to swap to a th350 just for the weekend to see how it runs with an auto. gonna take the th350 out a friends car w/ his tci 3500 stall and use his quick silver shifter and flex plate his has the 6" tailshaft so What all Would I need to swap?
a longer drive shaft?
will the th350 bolt up?
will i be able to use my m6 crossbrace?
aint worried about the speedo working since its just for the weekend
ttt
can the m6 crossmember work or do I HAVE to get another one?
what about how the torque arm mounts up? is the only option to run a mid mount torque arm?
i know its people here that have done the swap!
Brian, I did this TH-350 swap about three
years ago and to the best of my memory this is what you will need.
Crossmember from automatic F-body.
Longer driveshaft(your stock driveshaft
would work with a 9.5" tailshaft).
Dipstick from later model GM PU.
Tranny cooler/lines.
B&M tailshaft torque arm adapter.
Plate to cover big hole in floorpan left
by previous T56 shifter.
Wired neutral safety switch to bypass
clutch.
Emil Dusek:93Z,Th-350
clutch.
