strongest driveshaft ????
What is the advantage of an aluminum driveshaft over a CM shaft? Is the aluminum much lighter? I could see this being a benefit in a light/moderate use car if it is. This would essentially reduce drivetrain loss slightly by reducing rotating weight correct?
but CM should be stronger and close to the same weight as Aluminum price is probably another story (i havent ever priced a CM or CF driveshaft too an Aluminum)
RUENUF
Mar 13, 2016 03:37 PM
Aug 17, 2015 09:50 AM
