stock T-56 + 383... how long till it goes?
I was wondering who here has run a 383 on stock t-56? I have a viper shift fork and new syncros, but I know those wont make it last much longer. Anyone want to make a guess as to how many passes I can get out of it? Mods in sig, I am guessing 5-10 passes before it blows!!
Re: stock T-56 + 383... how long till it goes?
really? I will be getting LE2 heads, and a meeaan cam (hopefully)
how should I be careful just to make sure? what is best precaution at the track?
The clutch is a stage 2 spec, and I just checked it and it looks almost brand new still (25,000 miles) with under .020" of wear and last I drove it, it gripped like new.
thanks again
thanks again
thanks again
thanks again
My stock T56 is fine behind my 383, its held up to 8000+ street miles and a fair share of 5000rpm dumps on slicks....This is with a SPEC 4F, so don't worry about it. Just make sure its all the way in gear before you drop the hammer.
I love my spec, it grabs like nothing I have ever driven before... I guess it comes down to luck? Lots of my friends have gotten RAM clutches, and I would pick spec over them because of this kevlar clutch.
You'll probably never have a problem with the T56 on a single disk pull type clutch. They just won't hit hard enough to hurt the transmission. Go to a Twin Disk and you may snap an output shaft or gink up the splines in the slip yoke. Upgrade your T56 to a 31 spline output shaft and you'll have no worries. I have hundreds of 5500 RPM launches on my 31 spline T56 and my clutch hits very hard on with Hoosier 27X11.5's. For example, I've killed numerous 12 bolt R&P's (that's why I went to a 9") but the T56 is rock solid.
Steve
Steve
