Stock Pcm top speed
Old Jun 9, 2004 | 10:27 AM
Wildwill2855's Avatar
Stock Pcm top speed
with all the stock variables, stock tire sizes and pcm setup, what would 3.73s / 4.10s top out at in a 4l60E?Stock stall Then toss in a 3k stall and then what happens, just tryin to see what the differnce is here!
Old Jun 9, 2004 | 01:05 PM
rskrause's Avatar
Moderator
Re: Stock Pcm top speed
I am not sure what you are asking? If there is no speed limiter set in the PCM, your top speed will be limited by the rev limit and the amount of hp you have available. In the case of an A4 with a 26" tire, 6,000rpm would be 178mph in 4th gear with 3.73's and 162mph with 4.10's. Subtract a few mph for converter slip. But you still need the power to go that fast.
Rich Krause
Old Jun 9, 2004 | 05:17 PM
so then i could still probably run 125 then if i needed to still
Old Jun 9, 2004 | 08:53 PM
rskrause's Avatar
Moderator
In what gear? Yes, in OD. In 3rd, which is 1:1, 6,000rpm is 124mph with no converter slip and a 26" tire.
Rich
Old Jun 10, 2004 | 01:52 AM
thanks rkrause, thats what i was wantin to know!
DirtyDaveW
Dec 1, 2016 05:37 PM
95dzz28
Jan 12, 2015 05:58 PM
NewsBot
Jan 11, 2015 06:10 PM
mark0006
Dec 25, 2014 09:50 PM
siguy
Nov 27, 2014 10:07 AM
