Stock LS1 Rear-End on LT1???
Old 09-14-2004, 06:28 PM
1995CamaroZ28's Avatar
Would a stock LS1 rear end with 3.42's, and 3 series carrier fit my car
(95 Z28), which came from the factory with 2.73's, (2 series carrier)???
Is there anything that i need to modify, or change?
1995CamaroZ28 is offline
Old 09-14-2004, 06:41 PM
S8ER95Z's Avatar
Re: Stock LS1 Rear-End on LT1???
Yep, need to change the brakes/etc on the outter edges unless you want to do an LS1 conversion..not sure whats involved in that. I just had the mounting bracket, calipers, etc changed over to my new rear.
Running a 98 WS6 Rear.
S8ER95Z is offline
Old 09-18-2004, 05:16 AM
so what parts did u get, where, and how much..
Old 09-18-2004, 05:31 AM
Amped96's Avatar
My buddy, has an '02 rear end on his 93 Formula. It has the LS1 breaks and all still. I dont think anything was changed, but not sure cause it was like that when he bought the car.
Amped96 is offline
Old 09-18-2004, 05:41 AM
97WS6SCharged's Avatar
I'm not sure if the ABS system will work. One uses a 3 channel system, one uses a 4 channel system. Don't ask me which ones uses which, it's too early.
97WS6SCharged is offline
Old 09-18-2004, 07:01 AM
Dave89IROC's Avatar
only T/C cars used 4 channel, non-T/C cars were all three channel
Dave89IROC is offline
Old 09-18-2004, 01:59 PM
so, i got the 3 channel one?
i have the ABS unit under my hood on the passenger side..
Old 09-19-2004, 02:00 PM
if the LS1 rear end is a 3 channel, it should just bolt on with no problems??!
and, if it's a 4 channel, so i can say goodbye to my ABS?
Old 09-19-2004, 03:32 PM
Jerm982's Avatar
Are the LS1 rear ends any stronger than the LT1's?
Jerm982 is offline
Old 09-19-2004, 03:42 PM
atljar's Avatar
If your car has traction control, and so does the ls1, you are fine. If neither has traction control, you are fine. If they are mix matched, then your ABS wont work.
As said, you need to swap over the brakes too. You can run lt1 brakes, but you need to do lots of shimming to get them to work correctly. I had mine setup like that for awhile, but finally gave up (b/c it kept eating pads) and went to ls1 style brakes.
You also will need the ls1 parking brake cables
atljar is offline
Old 09-19-2004, 03:52 PM
Moore94Z's Avatar
You don't have to swap brakes if you swap axles. Use your old LT1 axles and everything will bolt right up.
Moore94Z is offline
Old 09-19-2004, 04:05 PM
so, do i need to swap the brakes or not?
you are saying that i can use my stock axles, and i should have no problem, and everything will bolt perfect?
all i need to do is to figure out if it came from a car with TC, and that's it?
Old 09-19-2004, 04:10 PM
Moore94Z's Avatar
Yes. The ABS connections are the same, as long as it is 3-channel.(connector on pumpkin) The brake issue is because the axles are different lengths on LT1 vs. LS1 cars. Use LT1 axles and all your stock stuff will bolt right up.
Moore94Z is offline
Old 09-19-2004, 04:21 PM
atljar's Avatar
Yes the axles are differnt lengths as said above. Pulling axles means pulling C clips, yucky job, although a much cheaper one.
atljar is offline
Old 09-19-2004, 04:42 PM
so what should i ask regarding the rear end to match excat and bolt right to my car?
thanks again
Quick Reply: Stock LS1 Rear-End on LT1???
