stock 10 bolt 7.5 or 7.625?
Old Mar 2, 2004 | 06:05 AM
adams_00_Z28's Avatar
The stock differential and ring gear in a 2000 z28 is 7.625 right? Could i run a 7.5 in it? What would be the draw backs of running a 7.5 instead of 7.625?
Old Mar 2, 2004 | 08:38 AM
come on, i know its kind of a stupid question but i really need to know so i can order parts.
Old Mar 2, 2004 | 05:38 PM
Capn Pete's Avatar
Yes, the factory 10-bolt from a 4th-gen uses a 7-5/8" ring gear (7.625"). I've got one in my garage right now waiting to be swapped in place of the 2.73's.
Old Mar 2, 2004 | 11:06 PM
Heatmaker's Avatar
Advanced Member
It can be either or with our cars...best way to find out what you have is to call your dealer and have them look the part up by your Vin#....they hsould be able to tell you exactly what's in your rear...but for the most part...gear manufacturers rate the gears as fitting 7.5's even though you may have a 7 5/8ths ...only time I've see nthe 7 5/8th get technical is when replacing the Posi unit.
Old Mar 3, 2004 | 06:02 AM
well im replacing my gears and posi, thats why i want to be sure that what i order is right. Would 7.5 gears fit on a 7 5/8 posi?
Old Mar 3, 2004 | 04:20 PM
Capn Pete's Avatar
Do you have the gears out of your car now? If so, it should be stamped somewhere along the outside edge of the ring gear, or just measure the gear.
Old Mar 3, 2004 | 05:04 PM
no, the gears are still in the car, its my daily driver. They are just whining like hell
Old Mar 3, 2004 | 05:07 PM
Heatmaker's Avatar
Advanced Member
Just call the dealer and have them look it up by your Vin...I had to do the same not to long ago...took al lthe guess work out...and it was FREE!!!!!!!!!!!!!!!!!!!!!!!
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
maybe2fast
Mar 16, 2015 09:45 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
