steal breaded line length for tranny to cooler?
Old Oct 22, 2005 | 08:58 PM
viper03af's Avatar
how many feet from the tranny cooler to the tranny?
Old Oct 23, 2005 | 10:16 PM
NastyTA's Avatar
Re: steal breaded line length for tranny to cooler?
I just did mine this week, I used two 1/4npt to -6 adapters, 2 -6 45* ends, a straigh end and a 90* end and bought a 15ft section or Russel line. Ended up using 14ft of it.
Old Oct 23, 2005 | 10:58 PM
viper03af's Avatar
thats what i was looking for thanks !!
Old Oct 24, 2005 | 09:42 PM
NastyTA's Avatar
be careful how you route it, it's hard to get it past the starter and header collector without being too close to the exhaust. I ran mine up over top of the stater, between the oil dipstick and the block, then under the oil pan rail to the front of the block. I made a bracket off of the fuel pump boss to secure the lines then went along the framerail and followed that up to the front of the radiator.
Old Oct 24, 2005 | 09:45 PM
viper03af's Avatar
i have a v6 so i have bit more room and the starter is on the driver side... ill run it with my oil return line should be fine there
thanks for the heads up the line is going to be hard to get around the up pipe
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
Jazsun
Dec 29, 2014 12:14 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
