stalled A4 vs. M6
Old Jul 25, 2006 | 11:45 PM
frankthetank078's Avatar
stalled A4 vs. M6
just out of curiousity what would u say is faster? an A4 with a stall around 3k or a regular M6
Old Jul 26, 2006 | 12:36 AM
StephenDeli22's Avatar
Re: stalled A4 vs. M6
At the strip the stall is, on the roadcourse it is the other way around.
Old Aug 1, 2006 | 11:51 PM
Red04StangGT's Avatar
Stalled auto FTW
Old Aug 2, 2006 | 09:37 AM
Capn Pete's Avatar
With a good driver, and no fear of breaking anything (tranny, driveshaft, gears) the M6 should give the stalled auto a damned good run. For an "average" pair of drivers, the stalled auto will likely take the win. This may even be true of 2 bone stock cars (because often stick drivers can't run the cars to their full potential).
But, put 2 competent drivers, and I think it would be darn close?
Old Aug 2, 2006 | 11:49 AM
94Camaro_Z_28's Avatar
^ yup. Depends on the driver. Mechanically, they're pretty equal. Slight advantage for the stall though...IMHO.
T/A Racer's Avatar
assuming you could get traction past 3,000 rpm wouldnt the M6 have the advantage if you held it above the auto stall. also doesnt the M6 retain a little more percent of hp to the wheels. assuming the shifts were dead on id say the M6 has atleast some advantages.
Old Aug 2, 2006 | 01:54 PM
383Z4ME's Avatar
That M6 has almost a 25 hp advantage, about 8%, with the losses through the converter and A4. On street tires that is probably 8% more likely to spin but a definite advantage to the stick.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
