stall recommendations
Old Jan 25, 2008 | 12:55 PM
Lil_Ryan's Avatar
based on the build in my sig, how big a stall would you run.
ryan
Old Jan 25, 2008 | 01:34 PM
MyShibbyZ28's Avatar
I wouldn't be able to tell you much of what size stall to get, but I always thought the stall needed to be just a little lower than where your peak torque is. There's other factors that play in to it also, but I won't be able to help much there.
Old Jan 25, 2008 | 03:35 PM
Lil_Ryan's Avatar
thanks for the input at least. you are the first one to try.
Old Jan 25, 2008 | 03:40 PM
Rice Killer87's Avatar
Your a stick now,I take it your putting in an auto?
With that camshaft,I would say a 3,000-3,200 stall. With those gears you'll hardly notice it driving through town.
Old Jan 25, 2008 | 05:36 PM
Lil_Ryan's Avatar
yes. i will be swapping to an auto. thanks for the advice. thats exactly what i was thinkin.
Old Jan 25, 2008 | 07:18 PM
cause4panic's Avatar
trade a built auto for ure m6?
Old Jan 25, 2008 | 08:55 PM
Lil_Ryan's Avatar
pm sent
Old Jan 26, 2008 | 06:34 AM
Z-RATED94's Avatar
What kind of rpm does it pull? How tall are your rear tires? I'd lean more towards a 3600 if it wouldn't make you run out of rpm crossing the line. That's if you take it to the track? WELL, DO YOU?
Old Jan 26, 2008 | 06:47 AM
Lil_Ryan's Avatar
i have 315/35/17 in the rear and spin to 6500rpm. i do want to go to the track, but not with the m6.
Old Jan 26, 2008 | 07:10 PM
LT-x7's Avatar
How would ANY converter make a car run out of rpm crossing the line?
I would go 3600-4000 if it was my car.
Old Jan 26, 2008 | 07:13 PM
I think he means shifting to second gear too early.
Old Jan 26, 2008 | 10:39 PM
Z-RATED94's Avatar
I take it your serious. So why don't you think about the variables involved when considering the optimum rpm when crossing the finish line.
Old Jan 27, 2008 | 12:57 PM
LT-x7's Avatar
OK.....
Trap speed and gears, (gears including trans, tires, and rear end) hmmm thats it, am I missing something?
The only way a converter could effect your finish line rpm is if it increased your trap speed. Unless of coarse you have a 6000 stall.
Please explain how a 4000 stall effects rpm on the top end.
Old Jan 28, 2008 | 09:14 AM
AL SS590 M6's Avatar
Moderator
OK.....
The difference in trap rpm with a 3000, 3500, 4000 will be zero if the efficiency <sp> is the same. What stall rpm is has nothing to do with trap rpm.
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Beave2780
Sep 23, 2015 12:37 PM
tommalcolm
Sep 11, 2015 03:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
