stall recommendations
I wouldn't be able to tell you much of what size stall to get, but I always thought the stall needed to be just a little lower than where your peak torque is. There's other factors that play in to it also, but I won't be able to help much there.
thanks for the input at least. you are the first one to try.
What kind of rpm does it pull? How tall are your rear tires? I'd lean more towards a 3600 if it wouldn't make you run out of rpm crossing the line. That's if you take it to the track? WELL, DO YOU?
Trap speed and gears, (gears including trans, tires, and rear end) hmmm thats it, am I missing something?
The only way a converter could effect your finish line rpm is if it increased your trap speed. Unless of coarse you have a 6000 stall.
Please explain how a 4000 stall effects rpm on the top end.
OK.....
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
tommalcolm
Sep 11, 2015 03:39 PM
