Stall converter help, suggestions
Old Mar 15, 2006 | 08:11 PM
stepuptata's Avatar
My car has a 224/236 cam @.050 and .555/.565 lift @ 114. I have a 342 rear gear. This is street driven only, not raced. What size stall speed converter should I go with? Thanks for any suggestions, Troy.
Old Mar 16, 2006 | 05:51 AM
Pro Built Automatics's Avatar
Re: Stall converter help, suggestions
How do you drive? conservatively?, moderately?, moderately aggressive?, or
aggressive? This has a lot to do with what stall you might want/need. Do you do straight line acceleration, or more of a road race style of driving on the street?
Old Mar 16, 2006 | 04:16 PM
stepuptata's Avatar
This car is rarely driven. When I do get on it, Its in a sraight line. I never plan on road racing. I guess I need a stall because, When the car is in park and I go to put it in gear (with foot on brake). it wants to lunge forward. Will the stall cure this??? Thanks for the help, Troy.
Old Mar 16, 2006 | 05:02 PM
A higher than normal idle will cause this. Yes, the smaller diameter torque converter will soften the hit from park to drive. I wouldn't go to a smaller diameter torque converter just for this reason. You want a stall that matches the cam, how you drive, etc. I would recommend a stall from just what you told me at around 2,600-2,800 rpm.
Old Mar 16, 2006 | 08:04 PM
stepuptata's Avatar
THats exactly what I was thinking ,@ 2800. How difficult is this going to be to change? I have high mechanic ability, I just haven't missed when a tranny on a 4th gen. Thanks.
Old Mar 16, 2006 | 09:28 PM
nikkev's Avatar
The hardest part is getting to the bellhousing bolts. Other than that, it's a pretty straightforward job. I can swap mine out in about 2 hours and I'm pretty slow. I have some friends who can do it in around an hour. There used to be a write-up online, but I can't find it anymore......
Edit: found the write-up:
http://www.zmydust.com/converter.html
Old Mar 17, 2006 | 05:17 AM
stepuptata's Avatar
cool, thanks, Troy.
thenewkid
Apr 12, 2015 07:42 PM
marine1bird
10
Jan 25, 2015 12:02 AM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
veryslowfbody
Aug 22, 2002 04:31 PM
