squealing on left turn
Old Jul 20, 2005 | 03:50 AM
WS6Formula2004's Avatar
I have a 95 firebird formula, when i make a left turn at more than 10-15 mph i get a squeal it sounds like it is comming from the front,
any ideas, {it only happens on left turn}
Old Jul 20, 2005 | 07:20 AM
Bow94z's Avatar
Re: squealing on left turn
your tires does not have the correct pressure...is it comming from the tires?
Check your tire pressures first, then report back
Old Jul 21, 2005 | 05:07 AM
its not tire pressure all tire pressure checks out fine
Old Jul 24, 2005 | 02:37 PM
roguedriver's Avatar
Check your rear rotors for wear that isn't normal around the outside edges of the rotor. It may be your calipers rubbing the rotors due to C-clip related axle slop. When you turn, your axle wants to slid out of your rear end, and since your rotor is on your axle, it want's to come out with it, but your caliper is bolted to the housing, so that stays. Theres pretty tight tolerences between the caliper and rotor, so it's easy to rub once you get some slop back there. I had to take a dremel and take a little off my calipers where they were rubbing on my camaro before I got my 12 bolt with C-clip eliminators. Let us know.
Ken R.
Old Jul 24, 2005 | 03:35 PM
My Iroc Z28's Avatar
Or it could be the rear wheel bearings, i have the same problem in mine, im just waiting for the 12 bolt swap.
Old Jul 24, 2005 | 10:42 PM
I second that one. A wheel bearing is definitly another possibility. If your calipers are rubbing the rotors, you'll see where there rubbing on the rotor. If not, then the other squealer could be a wheel bearing like stated above.
Ken R.
Old Jul 24, 2005 | 11:46 PM
Z28Nut's Avatar
Done anything to screw up the alignment lately? Or the ball-joints/tie-rod ends are worn. That could be causing a tire to squeal on turns. My Blazer was doing that, took it in for an alignment and 4 ball-joints later, it still squeals the fronts around corners, albeit at a higher speed. Damned top-heavy whale.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CaRParts102
Dec 6, 2014 08:45 AM
formula79
26
Aug 5, 2002 12:21 PM
