Is a special scan tool needed to bleed brakes?
Old Apr 21, 2015 | 08:26 AM
Rod Bender's Avatar
Is it possible to bleed the brake system on a 96 Camaro that has traction control and anti lock brakes without some special equipment? My Haynes manual says to take the car to a shop that has a Tec 1 or T100 scan tool. At this point it appears I need to remove my brake booster and hence the brake master cylinder to install my new clutch master cylinder. I do not care if my ABS is inoperative as long as the the brakes work otherwise normally.
Old Apr 29, 2015 | 09:03 AM
Z28Freak86's Avatar
Re: Is a special scan tool needed to bleed brakes?
You do not NEED to use the tool tech 1 to bleed the brakes, you do need it if you want to bleed the abs module automatically and correctly. But the whole system should bleed normally like any other car. I've done this a couple of times, it still works. The abs may not work, but as you said you dont care. so yes you can bleed it normally. just get the air out of the line and you should be good to go.
Theres ALOT of brake lines on this car with a ton of places for air to get trapped. Having a power bleeder helps getting this job done
Old Apr 29, 2015 | 09:32 AM
If you have a code set for the ABS system, the motors have to be "homed".
Old Nov 7, 2023 | 02:30 PM
eric lloyd's Avatar
yes you need to unlock the abs system because if you have a leak in your rear braklines the abs system will not allow brake fluid to travel to the rear calipers . Therefore you need to fix your problem then have the machine unlock the abs system to allow the brake fluid travel back . When it happens you'll hear a kinda loud pop and that's the abs system letting the fluid go !
JB94
Nov 26, 2006 12:17 PM
SpeedDemon02SS
10
Nov 2, 2005 08:07 AM
SlickBlack Z
Feb 2, 2004 12:51 PM
ZDriver96
Jan 5, 2004 06:30 AM
ZDriver96
Mar 20, 2003 09:34 PM
